Dismantled MUs goes to different successors
Hi, I'm new in Plant Simulation, and I want to learn how to make dismantled MUs goes to different successors? My process is to assemble two entities on a container, then dismantle it, the entities goes to the next singleproc and the container goes to buffer to rotate in a cycle. I have attached my trial, can anyone please help me? Thanks!
Re: Dismantled MUs goes to different successors
you don't need the flowControl; select in the DismantleStation as Sequence "Main MU after other MUs", fill the Dismantle Table. In the Dismantle Table you can set a successor for the parts, the successor for the container you set in the field "Main MU to successor"
You should create one container in the buffer, so that the simulation can start.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
