Display icons in 3D view
Innovator
Innovator
Instead of using text "Temperature", is it posssible to show temperature icon in 3D view.?
Re: Display icons in 3D view
Where do you want to replace the text by an icon ?
Innovator
Innovator
In place of that text temperature, I want to show a temperature icon in 3D view itself.
Assuming you mean the displayed text from a comment- or display object in the 3D viewer,
I guess you cannot replace the text characters by icons.
But you can add a textured plate with the icon to hide text characters  (s.b.)
If it is sufficient to use monochromous "icons", you might find something suitable in the unicode character table. In that case, use whatever icon suits you as the prefix text.
Innovator
Innovator
Could you please attach this model.?
I'm afraid , but I've already deleted the model.
But - as posted before -you just need to import the attached temperature01.png on a 3d textured plate.
and place it over the text , you want to cover /replace by the icons.
Important for the right display of the icon in 3d are the icon dimensions ( 359 x 553 pixels)
When importing the icon to the textured plate, please set the plate dimensions (in m)  accordingly (s.b.)
