Display panel in 3D view
Innovator
Innovator
I want to add 3 parameters say temperature,pressure,quantity and respective values and show in single box one below the other. Eg:
Temperature:   32deg
Pressure:    234
Quantity:  4
I used display panel which is visible in 2D but not visible in 3D view. Is there any way we can see in 3D view.?
Or is there any other altermnative to do this.?
Re: Display panel in 3D view
Hello Sahana,
there is also a 3D Display object found in your "Toolbox" under the ribbon "User Interface". Have you tried that one already?
Kind regards,
Igor
Innovator
Innovator
Yes I have used it at present. Please find attached image.
Instead of showing it individually, I wanted to show  those 4 parameters in a single box
As Igor already mentioned, there is the DisplayObject - which is the reason why the Display Panel never was introduced to the 3D visualization as the DisplayObject was introduced as better alternative to the Display Panel. The discussion technically is still not over whether one day a Display Panel might be introduced to 3d, too (which mainly depends on good reasons for that introduction), but as of now, there are no immediate plans.
By the way a hint on another topic:
If you attach pictures as MS Word documents, you accidentally reduce the chance that someone looks at your attachment. Contrary to a MS Word document which may contain macros that might harm a computer, simple image files are rather safe - and thus much more likely to be opened by others, as anyone who stumbles upon the MS Word document might want to avoid getting into unknown trouble by opening a harmful file.
I don´t miss the panel (because of it´s handling it became never my favorite) ... just arrange variables and/or displays in a frame, so it´s easy to place them in common ...
Always consider using the AttributeExplorer!
@sahana_s
Have you tried the comment  object (s. below ) ?
@sahana_s
Here's a little model using the comment object as a sort of panel.
Innovator
Innovator
Thank you Smiley Happy i will try this out.
Innovator
Innovator
I have version 14 and this model is not opening.
Here's a version 14
