Display table value
hello,
I have a table with many data inside.
I wish to display some of them to follow my simulation running.
When I write the pa table[x,y] in the object "Display" , it writes (?) and not my value.
Is it possible to dipslay a value, or a range of value which com from a table ?
Thanks in advance,
Re: Display table value
Hi Jer_N,
I would guess that you have the display object as being on watch mode. Unfortunately you cannot watch the values in a tablefile and you can only sample them. You do this by changing the mode to sample and making the interval small to reperesent the fact you are watching the value.
Ollie
Oliver MacFarlane
Simulation Engineer
web: www.simsol.co.uk
e-mail: oliver.macfarlane@simsol.co.uk
