Display the Status of machine Dynamically using a Variable
Dear All,
I have a request where the utilization of machine needs to be displayed in simulation and value should change dynamically.
(eg) Machine 1 - Working time is :
Machine 1 - Waiting time is:
Machine 1 - Blocked time is:
Is it possible to display them?
I know it is easy to take it from Charts but this is an option I would like to explore.
I did a similar activity for displaying Current state of the machine as below:
I have added a comment for each machine and added an observer to them for recording "ResCurrentState" and method executed is :
if ?.resCurrentState ="Blocked" then
    Comment3.text:="Waiting for Operator"
elseif ?.resCurrentState ="Waiting" then
    Comment3.text:="Waiting for Part"
elseif ?.resCurrentState ="Working" then
    if ST20_Pos=1 then
        Comment3.text:="Manual process"
    elseif ST20_Pos=2 then
        Comment3.text:="Auto process"
    else
        Comment3.text:=?.resCurrentState
    end
else
end
Re: Display the Status of machine Dynamically using a Variable
have a look at the methods for accessing Statistcs
in the help file
Betreff: Display the Status of machine Dynamically using a Variable
Do you know the attributes "statBlockingPortion","statWorkingPortion","statWaitingPortion",...?
__________________________________
Have a look in the help before asking.
EDAG-PS: https://www.edag-ps.de/
