Distribution code Question
Hello at all!
In the attached model , I have a question whether the code I write to  define destination of PickAndPlace is right or not.
That Pallet A all go to Line1, and 50% of Pallet B , 90% of Pallet C go to Line1, as the others go to Line11.
I will really appreciate for your help!!!
Have a nice day!
4 REPLIES 4
Re: Distribution code Question
the name of the container is A,B and C you you need to check @.name not @.muPart.name (that returns the name of the part inside the container).  Since you have an else-condition (all to line11), you can simplify your code:
var i,j: real
i:= z_uniform(1,0,1)
j:= z_uniform(1,0,1)
if @.Name="A"
	PickAndPlace.SetDestination(Line1)
elseif @.Name="B" and i<=0.5
elseif @.Name="C" and j<=0.9
else
	PickAndPlace.SetDestination(Line11)
end
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank u so much!!!
Hello,sir!
I am sorry to bother you with another problem that after the sorting the products go to the high-bay warehouse and will not be stored.
If there any problem in the setting of racklane?
you have already the method userSetTarget in your frame; this method you need to call using a sensor on line11;
after line1, you need another conveyor to connect the second rack
I guess, in your constallation you will need two WMS objects and also two userSetTarget methods (you need to change the second one to adress the right WMS)
Steffen Bangsow
web: www.bangsow.eu
