Doing Loop until cell empty
Hi everyone,
I have a loop that's working nearly perfect.
for var i:=1 to main.yDim loop
  main.erzeugeSubliste(4,i);
  main[4,i] [1,1] := "Color";
  main[4,i] [4,1] := main[5,i]
next
Now I have the problem because the yDim is variable the loop is not stopping if the cell is empty.
So I wanted to modify my code that the loop stops while the cell is empty.
I tried this:
if main [3,i] /= " " then
next
else
doContiunue:= false;
end;
but its not working...
Can someone help me?
Thank You.
Best regards,
IceTea
3 REPLIES 3
Re: Doing Loop until cell empty
Hi IceTea,
I'm not sure what u want but my first intention was:
"he hast to put the exception into the loop"
so something like this:
  end;
next
or you create a new boolean variable
maybe you can specify your question?
Based on the code attempt you have pasted I think I know roughly what you are trying to do.
The following untested code should loop until it reaches a empty cell and then stop looping, reguardless of if there is more cells with data futher on within the table.
for var i := 1 to main.yDim loop
  if main[3,i] /= "" then
    main[4,i][1,1] := "Color";
    main[4,i][4,1] := main[5,i];
  else
    exitLoop;
  end;
next;
If you instead want it to keep going but ignore any empty cells then you should remove the else case of the if statment and you will get to what C__M has suggested.
JamesM
This was the mistake.
Thank You!
Now its working Smiley Happy
