Doubt about Container
Good afternoon.
In my project I have a 'container' that is loaded with a quantity of plates for transport. When arriving at the destination I can not take these plates the 'container'. Does anyone know how to proceed?
Re: Doubt about Container
What is your approach, what is the error-message? Can you post your method?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I'm using only one 'for' to iterate:
plates:= @.numMU;
for local i := 1 to plates loop
@.cont.move;
next;
The iteration progresses, but none piece is removed from the 'container' (@).
what is the destination of the MUs? And how do you call this method?
Steffen Bangsow
web: www.bangsow.eu
The container is on a 'SingleProc'. The method is executed in onExit event. I need the plates to be moved to a 'buffer'.
If you want to move to a buffer, then you should include a little delay, so that the MUs can step foreward. Move without a destination works only, if the location of the mu is directly connected with the destination, so try this:
plates:= @.numMU;
@.cont.move(buffer);
wait(0.001);
next;
Steffen Bangsow
web: www.bangsow.eu
It's work.
Thanks.
