Dynamic worker assignment by brocker
Hello  All,
I have a problem regarding worker assignment by brocker. In my test model,  I made 3 single processors with different processing time. Total worker number is 3 in workerpool.
Single proce  and 2 have shorter process time compare with single proce1.  I realized only single proce and single proce 2 got worker assignment by brocker. Is it possible that early finished worker can help longer process time single process?
In the test model, single proce2 has only 2 min process time, after that I would like to assign this the worker at single proc2  to single proc1 with other guy.
besides, I would like to get job allocation advice using by brocker
Many thank you inadvance.
Re: Dynamic worker assignment by brocker
Hello sjsg,
you need to extract the engaged workers from "workersToBeExported" table. You have also to compare the available and needed workers for a singleProc.
Enclosed you find your extended modell..
Thank you for reply.
Unfortunately, your version is higher than my version (12.0).  So I could not open the file...
Can you kindly help me out to save the file as slightly lower version?
Thank you so much!!
Much Thank you!
