Edit icon of Frame
Builder
Builder
Hi everyone,   I'm trying to see inside layout of a frame without opening it.  Is it possible?
example:- In my model, the source connected to the frame which contains 2 SingleProc then this frame connected to another frame, now I want to see full structure of model without opening any frame. Is it possible? How?
Re: Edit icon of Frame
Hi!
You can try the following:
- Open frame with singleprocs
- On "General" ribbon click Representation button
- Use "Contents" mode
This way you can display all (or some) of frame contents in the root frame.
Regards, Vladimir.
Builder
Builder
