Emptying store evety 30 min
Hi
I would like to send 100 items from store do the next station every 30 mins?
How can i do that?
10 REPLIES 10
Re: Emptying store evety 30 min
you can use a generator, that calls a method every 30 minutes, within the method you can use a loop to move the parts e.g. to a parallelProc:
for var i:=1 to 100 loop
  store.cont.move(nextStation)
next
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
is
        store.cont.move(Line311)
    next;
do
end;
Reports syntax error near line 2 at "for"
okay, old syntax: you need to program between do and end
if you move to a line, you need to wait, until the line is empty (or at the entrance is space for the next part)
is
i:integer
do
    for i:=1 to 100 loop
        store.cont.move(Line311);
        waituntil line311.occupied=false prio 1;
    next;
end;
Steffen Bangsow
web: www.bangsow.eu
Ok. That syntax is ok. Thanks.
But how do I insert that method with generator part in store?
insert a generator into your frame, set an interval of 30 minutes in the generator and assign the method as interval control
Steffen Bangsow
web: www.bangsow.eu
I have created a method with the code that you have suggested.
Also I created a generator and under tab control and interval inserted method.
this happens, if your store is empty
what do you want to do, if your store is empty ??
Steffen Bangsow
web: www.bangsow.eu
Store items. Wait untill it reaches 100 and then send it to next process
okay, this you need also to include into the method, e.g. do nothing, if there are not 100 parts in the store
is
i:integer
do
-- do nothing, if there are not 100 parts in the store
if store.numMu < 100 then
return;
end;
next;
end;
Steffen Bangsow
web: www.bangsow.eu
