Emptying store onto a line
Not applicable
I was wondering if anyone could help with guidance of how to empty a Store onto a Line. I understand it's possible using a Method but any guidance would be appreciated.
Re: Emptying store onto a line
To empty a store with a Method is simple, just move the store content to the line.
the method text is
is
do
store.cont.move(line);
end;
In case you want to put the part on a certain position on the line use e.g. store.cont.move(line,2.3);
You have to rename the jpg into .spp to run the Plant Simulation 10.1 demo model.
Not applicable
thanks a lot that's great!
Where do you assign the Method?
