Energystatistic for a car
is it possible to show the energystatistics for a car with the tool "energy analysis"?
Or does it only work for objects?
Thank you!
Re: Energystatistic for a car
not directly, but you can use a "dummy" object for transfer the energy states, if the transporter changes its state
see here an example
https://www.bangsow.eu/detail_en.php?id=688
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
i tried to apply the dummy, but i couldn't find it.
Is it selectable in the toolbar?
Best regards
you can take a singleProc to transfer the energy states
Steffen Bangsow
web: www.bangsow.eu
do i understand it correctly?
I can connect my car (which trnasports movable objects) with a single proc, to transfer energy stats of the car. Ater that i could evaluate the stats with the energyanalyzer...?
But how can i realize the trasnfer of the energystats?
thank you and best regards!
you can change the energy state of e.g. the SingleProc with energyCurrentState, so the approach is:
if the state of the transporter is changing (e.g. observer for the attribute currentSpeed or targetPosition), you change the energy state of the corresponding energy-object (dummy).
Steffen Bangsow
web: www.bangsow.eu
should i realize it with a method?
i dont understand it completly how i can realize the transfer of energystats from a transporter to a single proc so far...
In my mind, i want du declare some energy stats for the transporter and display them after the end of the simultion...?
best regards
what do you want to show at the end of the simulation?
Steffen Bangsow
web: www.bangsow.eu
I want to declare some energystats for my transporter. e.g. the total consumption of the transporter ( some energyvalue per meter or something else)
that i have a displayable resulst after the end of my simulation.
do you have some ideas?
best regards
keep it simple; if you only want to show the total power consumption you can use at the end the statTranspArbeitszeit and statTranspwartezeit to calculate the total power consumption (if you have two different energy states)
Steffen Bangsow
web: www.bangsow.eu
