Enrror: Unload not possible, no space on target.
I have a problem with my model. I have a containerA and entityA attached. I am dismantling them and putting entityA in other containerB. Then, I am trying to put other containerA in the containerB. However, Size is too small for containerB. ContainerB suppose to come from the converyor. If I increase the size of ContainerB then it waits for more entities. How can I resolve this? It seems like I have to play around with the sizing of container. I am attaching my model for visualization on what I am doing.
Ultimate goal is I am suppose to put more entities in containerA on other station then put it in containerB.
Thank you,
Manan Trivedi
Re: Enrror: Unload not possible, no space on target.
you could set the capacity of the container in the exit-control rear of the source2:
@.xDim:=4;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hi Steffen,
If I increase the capacity then it waits for four parts at Sensor 1 position. I would like to have wait for four parts in sensor 2 position and for one part at sensor one positon. Sorry I am very new this so I might be bit slow.
Thank you,
Manan Trivedi
Hi Manan,
you can set the number of parts in the Transferstation in Tab "Advanced Attributes". Deactivate "all" and set the number of parts in the field blocks.
Best Regards,
Steffen
Steffen Bangsow
web: www.bangsow.eu
Thank you! It worked!
