Error Message meaning
Hello guys,
I'm getting the following error when I try to run a model:
Is it the kind of error that occurs because the path is too long?
All help is much appreciated. Thank you
Re: Error Message meaning
You will get this error message if the list or table has fixed dimensions, and if you try to access a cell outside this range.
Thank you!
Sorry guys for bumping up this thread again but this error seems to be beyond me this time. A simple access to a table with column index is somehow not working :@
Help please!
The only explanation I can think of is that there is some leftover stuff in the row index (column 0). Please activate the row index and check if that column has the index "PrioID". If this is the case, please delete the index and the content of column 0 and then deactivate the row index.
If the row index is empty, I have no idea what is going wrong. If you upload your model I will take a look at it.
Now that was a sick guess and worked perfectly. Thank you SO much!
