Error Report
Hello Siemens,
I am just playing around with 3D and found this. I intentionally entered zero on the scale in 3D Properties for MU. And when I did that, I get an error saying "Enter Non Zero value". But, I am unable to close the dialog and make changes again. Is everyone facing this problem or is it just me? Thank you.
-Simpulse
Re: Error Report
Hello Simpulse,
when I try it I can change the value without problems after getting this error message.
Which version of Plant Simulation are you using?
Ralf
Re: Error Report
I am using Version 12.0.0.
The Dialog Comes up initially. And when I try to repeatedly Close the Dialog, it Shows up another Dialog with no values or text in it. And after trying to Close it for a while, it finally Closes.
The following is the second error message I told you about.
Re: Error Report
Thanks for the error report.
I suppose you closed the dialog by pressing the Return key. This problem has already been fixed in the currenct maintenance pack 12.0.5.
