Error in Neural Network
Hello All,
I was trying to get some understanding of Neural network by starting with basic models. in the first attempt itself i am getting a error message as shown in the pic. i get this message when i click on show Table or show chart in the Forecast Tab.
Can anyone help me in understanding what is the thing I am missing?
Thanks in Advance!!!
Re: Error in Neural Network
this looks like an error that was already fixed and that should disappear if you update the NeuralNet library. What version of the library are you currently using?
Kind regards,
Igor
Hi Igor,
I am using profressional licence,Plant simulation Version 14.0
if you use the attached library instead the error should disappear. Should you have any further questions regarding the results you might get after this feel free to ask, as although the error might disappear, there still might be some remaining inconsistencies with your inputs.
Kind regards,
Igor
Thank you!! It works now
