Error in Plant Simulation
Gentlemen, good morning.
The error below began to happen on my system from when includes a method Importer Broker.
When the error is triggered, the program closes. When I open the program again any action I try to run the error window appears and the program closes.
I lost everything I was programming?
Re: Error in Plant Simulation
Hello Martins,
when you selected 'OK' in the box below your model should have been saved under the path shown in the box at the end.
The next time you start Plant Simulation it will ask you if you want to load this model.
Are you able to post a model where we can reproduce this crash?
Ralf
Ralf
Follows the model..
Note: my version of PS is 11.3..
Hello Martins,
this bug is already fixed in the current patch of V11 (11.0.7).
Are you using the student version of Plant Simulation?
(This version is currently based on 11.0.3)
Ralf
Ralf
This version was acquired by the company he works for. Stardard version (11.0.3.705).
Then I'd recommend to download the latest patch from our GTAC server.
You can get the download línk in the help menu of Plant Simulation.
Ralf
