Error in check in a model to teamcenter
Hi
 I am working with plantsim and teamcenter integration.
When I duble click on plantsim model, it will be oppened correctly, but when I want to close it, I faced with attached error in teamcenter.
Can you help me to solve this error.
Best Regards
Iman
1 REPLY
Re: Error in check in a model to teamcenter
Please refer to my reply to your previous topic 'disable back up feature'.
