Error in model from GAWizard.StatisticalEvaluation
I get an error within GA's internal methods. I have attached screenshots of the error messages. I use Plant Version 12.2.6.
I do not know what could have been the cause of this issue. But as you can see in the screenshots, for some reason GAWizard.StatisticalEvaluation have empty cells, which I believe is why it fails.
Does anyone know why this happens, and how it can be fixed?
3 REPLIES 3
Re: Error in model from GAWizard.StatisticalEvaluation
Hello Busck,
the picture error_2.PNG shows that the mentioned tablefile is correct except for a single line (row142).
I believe that something like that can not happen.
Did you opened and changed this tablefile during the optimization?
I recommend to restart the optimization.
Can you upload the model?
Peter
Hello Peter,
I have not changed the tablefile during optimization. I have tried to completely remove GA from the model and its results, added it again and still get the same errors. If possible, could I please get your email adress and I'll send the model to you directly.
Your model would be helpful.
petermichael.schmidt@siemens.com
