Error in saving output
Hi guys,
I get the following error when saving output of different runs and experiments. Anyone who knows how to solve this?
11 REPLIES 11
Re: Error in saving output
the variable my has not the same data type like the column in your table.
Maybe, you need to convert the data-type like in the comment mentioned (e.g. str_to_num(...)).
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hi Steffen,
When I change the format of the column, the same message pops up. (They're both real now).
what value you get, if you copy detailRes[colRes,rowRes] into expressions --> first column?
If colRes or rowRes is zero, you get the value of the index and this is every time of type string.
Steffen Bangsow
web: www.bangsow.eu
I'm sorry, what do you mean?
The variables colRes and rowRes are both 1, so it's not the index..
in the debugger (foot area) you have a tab expressions, there you can check the value of an expression. In the first row you can insert an expression (in your case: detailRes[colRes,rowRes] ), in the second column you see the value of the expression.
Steffen Bangsow
web: www.bangsow.eu
The value is 'Table: instantiated'?
Hello WilliamK,
there was a problem in the Experimentmanager.
Do you have the possibility to update?
Which version of Plant Simulation do you used?
Peter
I'm afraid I've not the possibility to update. I'm using version 10.1, educational license.
So is there something else I can do? I cannot save anything manually...
