Error msg in Plant Simulation model
Hello everyone,
Does anyone know when the below error occurs?
Thank you!
Re: Error msg in Plant Simulation model
Hi GS,
something seems to go wrong internally regarding the Shift Calendar.
Can you post the model where this crash happens?
Ralf
Ralf
