Error msg when open 3d viewer
I get an error when trying to open the frame in 3d viewer. I work in ver Tr3/
Re: Error msg when open 3d viewer
Hi Shimon,
this problem is caused by the driver of your graphic adapter.
Can you please check that you have the latest version of the graphic driver installed?
Or if you have a notebook with an dedicated graphic adapter plus the integrated CPU graphic please make sure that the dedicated graphic adapter is used.
Ralf
Ralf
