Error when opening the model - incorrect method
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
Hi All, when opening the Plant Sim model, I get a notification that some of the methods I use in my Line (Oven) are incorrect; I am using relative path in the Line control - anyone has got an idea why this error occurs and what I need to pay attention to? thank you What the method is doing, is setting the variable to the MU name that is entering the Line. I have similar methods for other objects, where no error message pops-up, but the Line does not seem to "like it".
5 REPLIES 5
Re: Error when opening the model - incorrect method
Hi Irina,
Can you post one of the methods that is mentioned in the error report?
Gert Nomden
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Siemens Pioneer
is do OvenName:=@.name; end;
Hi Irina,
I could not reproduce the error in a mini-model. But are you sure there is a variable OvenName that can be reached by the method?
Gert
Gert Nomden
Siemens Pioneer
Yes, I looked at a mini-model attached and the error is not there when closed and re-opened the model. I wonder how I can debug my big model to get rid of the notification. What's the efficient way without rewriting the whole frame/model and methods...please?
Hi Irina,
Personally I would open the original method and re-apply changes so that the code is checked again by the software, then save and reload the model. If that does not help I would send it to GTAC unless someone else has a suggestion.
Gert Nomden
Gert Nomden
