Exporter services from method
Hello, I am trying to asignate the services os a exporter with a method but I obtain an error when I run the code (a 'string' cannot accept the method 'Services').
Anyone could help me?
The code is:
for i:=1 to data.yDim loop
 if Data[2,i]="Exporter" then
  listatrabajos:=splitstring(data[7,i],",");
  .Models.Frame.data[1,i].services:=listatrabajos;
 else
 end;
next;
The table called data is
Re: Exporter services from method
try
str_to_obj(.Models.Frame.data[1,i]).services:=listatrabajos;
or probably even better
str_to_obj(data[1,i]).services:=listatrabajos;
