Fail failure profile
Hi all,
I am having some trouble to understand what the check box "Failed" in the failure profile dialog box means.
Can you please help me with that? I ran some experiments with it checked and unchecked, but the results were exactly the same.
Re: Fail failure profile
to manually (test) trigger failures ...
Always consider using the AttributeExplorer!
Ok, got it. Thanks!
