Failures.getTable with MTTR bounds
Hello everyone,
When using Failures.getTable and using lower and upper bounds on the Availability/MTTR failure, the value isn't transferred as is. Instead a calculated value is saved to the table specified to Failures.getTable. Am I doing this wrong or is it intended functionality?
I attached a simple model showing this, run the method called RunThis, and then compare the failure profiles of SingleProc and TargetProc. Also look at SaveTable  to see the MTTR value there.
Re: Failures.getTable with MTTR bounds
I would say this is a bug in the software.
We will probably change this in the future.
Thank you Michael!
