Filling buffers using a table in the init method
I would like to fill my buffers using a table in the init method as the amount of MUs varys.
I got a model that works (see attached file), but it is almost as much work as using "for" multiple times.
Is there a simpler solution to my problem?
Thank you,
David
Re: Filling buffers using a table in the init method
all data you need you will find in your table. You can use a nested loop the create the necessary amount of MUs in the buffers:
is
	i:integer;
	k:integer;
do
	for i:=1 to tabelle.yDim loop
		for k:=1 to tabelle[2,i] loop
			.BEs.Fördergut.create(tabelle[3,i]);
		next;
	next;
end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you very much. I greatly appreciate your constant help.
