Find Object AnyWhere in the Model
Hi all,
I would like to know if it is possible to find on object in the whole project/model.
I have SingleProcs duplicated as Workstation template. This template has methods IN and OUT included.
Once I instance this workstation I always have the same code everywhere.
If I search for an object it only gives what it found in the main frame and the methods which are located here.
I can select ".MaterialFlow" where I have duplicate my workstation template, but there will be no search result.
Kind regards
Marco
11 REPLIES 11
Re: Find Object AnyWhere in the Model
Yes,  s. example
The station object has been derived in frame and sub frame1
Sorry, but I don't know understand what you mean.
I like to take a variable name from any object, go to 'General' 'Find Object", past it here, press Find and get all locations where it is used.
if you want to find you Method in you should start in the top-frame (in the Class library) --> find object
If you want to find an object --> your class in the class library --> show inheritance (and you have all objects in every frame)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hi Steffen,
I want to find where (method) a variable is changed.
Ex: I have a global variable in the frame and like to search this kind of instuction changing the value "iVarName :=".
There is "SingleProc" duplicated to be used as template for workstations. This workstation template has an IN and OUT control method.
Your are right I can list all instances of this workstation, but that is not what I am looking for.
I am used to have a global search in other software editors.
Marco
and you checked the find-object function with option source code?
Steffen Bangsow
web: www.bangsow.eu
Thats a part of it only.
I like to get a complete list where a variable is used.
If I enter 'MaterialFlow' it will show me the first location in each method which is part of this folder.
I can type 'Basis' in the 'Look in' box, but there is no result.
you need to start the search in your top-frame in the class library (and including all subframes), but it will also only list all methods, not all lines in the methods
Steffen Bangsow
web: www.bangsow.eu
Thanks, I know a bit more.
I cannot get what was expecting, but I close the topic.
Hi..
Did you get a solution to what you were looking for? I think I have the same problem.
I am looking for the method which accesses a global variable defined in my root frame.
