Find and Delete User-Defined Attribute
Is there a way to access the User-Defined Attribute table to search for a User-Defined Attribute without knowing the entire name using SimTalk?
This is what I am trying to do:
I want to search for and delete all User-Defined Attributes of an object with the name starting with "t_."
so something like:
obj.setCursor(0,0)
while obj.find("t_"*)
     obj.deleteAttr(obj.CursorY)
end
Re: Find and Delete User-Defined Attribute
you find all in the help
numAttr
getAttrName(index)
deleteAttr(name)
e.g. (not tested)
var i:integer
for i:=obj.numAttr downto 1 loop
 if pos("t_",obj.getAttrName(i))=1 then --starts with t_
   obj.deleteAttr(obj.getAttrName(i))
 end
next
--> see the restrictions of deleteAttr !!
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you Steffen,
That worked beautifully.
I couldn't think of how to check if "t_" was in the first postion... Makes sense that the method is called "pos()."
Thank you again.
