Finding string
I want to check if the String1 contains String2. I am going to make little program which will be checking every letter in string1. If its "b" followed by "l" etc...
Example:
String1 := "Car is blue and new"
String2 := "blue"
Is there any faster way to do such a thing with simple command?
Thank you
DR
Re: Finding string
print pos("blue", "Car is blue and new")
Re: Finding string
Thank you very much ! Exactly what I was looking for Smiley Happy
