Finding the optimal processing time
Dear community members,
suppose we have this simple model
I would like to find the processing time of Singleproc that allows me to have a maximum MU waiting time  in buffer of 150 seconds.
Is it possible with Plant Simulation or should I try manually?
Thank you
Re: Finding the optimal processing time
you can calculate the waiting-time using @.entryTime in the exit-control e.g.
is
 waitingTime:time;
do
 waituntil singleProc.empty and singleProc.operational prio 1;
 waitingTime:=eventController.simTime-@.entryTime;
 if maxWaitingTime<waitingTime then
  -- set new
  maxWaitingTime:=waitingTime;
 end;
 @.move;
end;
Then you can use the ExperimentManager for changing the ProcTime of the SingleProc.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you Steffen!
Your help is always much appreciated
