Finish loading - Transporter
Hello everyone,
I have a situation where 29 parts are being produced on daily basis and stored in a Buffer. From here these 29 parts are loaded on to a Transporter and sent to an unloading station and later to drain.
This Transporter has a capacity of 6. So, the Transporter is taking 24 parts (6 parts * 4 times) and for the fifth time it is waiting for the 6th part because only left 5 parts are loaded. I want to finish the loadind here for the 29th part and repeat this process for 20 days.
Please help!
Sharad
Re: Finish loading - Transporter
How do you move the parts?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hello Steffen,
I am using Transfer stations to load / unload parts from Transporter.
Sharad
then you could change the capacity of the Transporter depend on the number of parts, you need to Transport (e.g. sensor on the track + method). The capacity you can set using the attributes xDim/yDim
Steffen Bangsow
web: www.bangsow.eu
Hello Steffen,
Do I need to count the number of parts delivered and reset it every day?
1st Round - 6 Parts
2nd Round - 6 Parts
3rd Round - 6 Parts
4th Round - 6 Parts
5th Round - 5 Parts
This is how it should execute.
if you create each day 29 parts (set it in the source!), you dont need to count the rounds (the last round will have only 5 parts)
Steffen Bangsow
web: www.bangsow.eu
Check this sample model. May be you will figure something out of it.
This model has the same process you explained. Parts getting produced 29 per day and they are moved in batch of 6 and the last movement will be of 5 parts.
Sachin
Thank you Sachin
Thank you Steffen
