Flow control : use next aimed predecessor information
Hello
I have a flow control with cyclic sequence configuration. When my simulation is running I can check in dialog window of flow control or just info window from which predecessor the flow control is waiting for a part.
Is it possible to have this information in a control method ? do we have access to this information ?
Thanks for your support
Best regards,
Christelle
Re: Flow control : use next aimed predecessor information
Hi Christelle,
This information is not accessible (double-checked it). You can create your own logic to make it accessible, but if that is a way of working depends on the goals of the model.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
