Frame Icon Change problem
Hello
I Want to make a my model's Frame showing like this example
How can i handle it?
Is it a Method? or PS has such a tool?
Re: Frame Icon Change problem
This example use the transparent frame concept. To reproduce:
  1. Create a Frame in the class library and add contents to it.
  2. Set its Representation mode to Contents (default is Icon) or to Contents with background
  3. Insert the frame in your model multiple times.
Gert Nomden
cardsplmsolutions.com
Thank you very much Nomden!
