GA Optimisation
Dear Community Members,
Hello. Is it possible to perform simulation based on the failure % of drain ? If yes, can you kindly let me know how ? I have tried to perform optimisation but unfortunately I am geeting an error. I have uploaded my model for reference. Thanks in advance.
Nisarg.
Re: GA Optimisation
          I went through you model. I couldn't find the keyword "statFailed" in the library. I think you are looking for the keyword "StatFailPortion". This will return failure portion in decimal with total run time being 1. To convert into %, multiply the value with 100.
replace   drain.statFailed    with   drain.statFailPortion*100
Cheers.
Re: GA Optimisation
Thank you for your reply. The problem has been solved. Smiley Happy
