GAwizard error message
I stumbled across an error when trying to open the tables "optimization parameter" and "fitness calculation" which are part of the GAwizard. The message reads as followed: Unbekannter Bezeichner DecimalSeparator (see attached screenshot).
I havent changed anything at all within the code since it is provided by Plant Sim.
Can anybody tell me whats the matter with this attribute?
FYI: I use Version 14.0 with an educational license
4 REPLIES 4
Re: GAwizard error message
this is an error in the library method
you can correct it: switch off the inheritance and replace ~ by tab
this should work:
var decSep:string := tab.decimalSeparator
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
It worked, thank you very much!
I am facing a different problem now:
As I want to optimize the sequence of a table, I am dragging it to the GAwizard while holding down the shift key. However, the Wizard does not recognize the table appropriately. Could this be related to the previous problem in any way?
looks not so bad, define the fitness value and press confirm; then the values in the optimizing parameters should change
Steffen Bangsow
web: www.bangsow.eu
