Getrowno issue
Dear community members,
I'm trying to get the row number in a tablefile.
I activated both column and row indexes as shown in the picture.
I created a buffer user defined attribute called "init", which should print the row number where the name "buffer" is located. Case sensitive not activated.
I used the following code
is
do
	variable:=tablefile.getrowNo(self.~.name);
        print variable;
end;
Variable is a global variable of type "integer";
The output is -1. It should be one.
What should I change?
Re: Getrowno issue
The proposed scenario seems to work when I try to recreate it.
Have you possibly added spaces in the Rowindex?
If not: could you upload your model?
Re: Getrowno issue
Here is the model
Re: Getrowno issue
Your method refers to the TableFile "tablefile", whereas the data is in the TableFile "LevelingData".
Sincerely,
Re: Getrowno issue
Many thanks
