Getting all Contents names of a buffer
Is it possible to get all contents name of a buffer? EXAMPLE : I'm creating MU's directly in a buffer (using Create command ) at a particular interval of time. I want to get all the MU's name (buffer contents ) at a particular time. How can I get the names of each MU's ? Thanks in advance
Re: Getting all Contents names of a buffer
The command contentsList gives you access to all MUs located on an object.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
