Graph variable time instead of percent
Hi everyone,
I have a simulation where I count the num of finished Entities at the end of my simulation and plot them into a graph. It is working perfectly.
My only problem:
The number is counted not by their arriving time its given as percentage.
Now I can see how many percent of my production already arrived but I would rater like to see at which time the Entities arrive. That's why I want to change the Y-Axis form the variable percentage the the variable time.
Is this possible?
Thank you.
Best regards,
IceTea
8 REPLIES 8
Re: Graph variable time instead of percent
have a look in the object TimeSequence (information flow, see help).
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hey Steffen_B,
thank you for your answer. But could you be please more precise?
I actually don't know what you mean...
Thank You.
Best regards,
IceTea
I see two ways:
- take a chart - set the type plotter and plot the data
- take a timeSequence - record the values of your variable in a certain interval - drag the timeSequence to a chart object
Steffen Bangsow
web: www.bangsow.eu
Okay thanks, than I understood right. So its another problem not the way to do it...
The problem is that I only have 20 Containers that are produced the TimeSequence listed over 100.
I don't understand whats happens here...
Could you explain it to me?
Thank you.
Best regards,
IceTea
you need to clean the TimeSequence at the start of the experiment, e.g. insert a method into your frame, name it "init" and write into the method:
timeSequence.delete
Steffen Bangsow
web: www.bangsow.eu
What a method I don't even have one...?
I'm a total beginner a have no idea by programming...
I did everything with the drag and drop function...
it is easy, in the folder information flow you will find the method; drag the method into your frame, rename it in "init", open it with doubleclick and type:
timeSequence.delete
That's it.
Steffen Bangsow
web: www.bangsow.eu
it was really easy and works perfect.
Thank You!
