HBW Edit
Hey community!
I just get problems with the HBW.
In default HBW, the RSU take the pallet and drop it at the same side of the track.
What if I want RSU to take the pallet at one side of the track and drop it at the other side?
How can I edit the HBW Object or create a new model to do this ?
8 REPLIES 8
Re: HBW Edit
edit the method placeIntoStock of the WMS (Navigate - Open object)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: HBW Edit
Yes, it's my original question.
Thanks anyway.
Re: HBW Edit
And I didn't see the method placeIntoStock have connection with that.
Re: HBW Edit
all methods for handling the parts in the RSU you find in the RackLane-object (hold the ALT key down and double click on the racklane).
or you create your own, see e.g. here
http://www.bangsow.eu/detail_en.php?id=727
Steffen Bangsow
web: www.bangsow.eu
Re: HBW Edit
Really thank to your patience!
Re: HBW Edit
Hi Zhou, Did you find a solution for this? I have the very same problem, and I cannot find a simple solution for this. I have looked into modifying the existing HBW library, but no success so far. I have managed to move the OUT-station to the correct position, but the RSU are still going to the IN-station to leave the parts. The parts are then teleported to the OUT-station. I need the RSU to go directly to the OUT-station, did you manage to solve this?
Re: HBW Edit
Hay guys,
im trying exactly the same thing, you tried. I want to load my rack from one side and unload it on the other side. But i cant get it done. What were your solutions ?
Re: HBW Edit
I started by unlocking the crane library to customize it. I got a bit further, but eventually decided to redo everything from scratch (with a multiportalcrane and two stores).
The main reason for doing this was that the two sides needed to be on different Z-positions in my project. I found it hard to change/adopt the current HBW-logic to this, as well as having the two sides on opposite sides of the crane. Besides, it felt like good training to develop something like this from scratch.
