HBW issue
Hi, Guys,
when I run my HBW model, the RemoveOderNo don't change and when a row in the HBW is filled, the entire model will get stuck instead of loading the pallet to another row. How can I modify my code?
Br.
Jill Li
6 REPLIES 6
Re: HBW issue
this is, because you assigned fixed products to racks... (WMS strategies)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: HBW issue
Oh, I see. so how to make some pallets remove and counting?  I made a method for remove but its seems doesn't work.
Re: HBW issue
there is already a method in the WMS (press the ALT key and double click on WMS).
There you find a method removeProducts. This is a good base for developing your own method or just use it.
The stock of the parts you can find in the table content.
Steffen Bangsow
web: www.bangsow.eu
Re: HBW issue
Thank you. I know what you mean, but as a beginner, I don't know how to use fixed method in WMS.
Re: HBW issue
this is easy:
look, these are the parameters of the method
param OrderNo : string, product : string, quantity : integer
the call would look like this
orderNumber+=1--global variable type integer
--remove D from store
WMS.removeProducts(to_str(orderNo),"D",1)
that's it
Steffen Bangsow
web: www.bangsow.eu
Re: HBW issue
That's really helpful. Thank you!
