HELP! How to transfer tablefile from SQLite in plant simulation to Microsoft SQL management studio
HELP PLEASE! How do I  transfer tablefile from SQLite in plant simulation to Microsoft SQL management studio so that my microsoft sql can contain the tablefile???
Re: HELP! How to transfer tablefile from SQLite in plant simulation to Microsoft SQL management stud
two steps:
- read the complete content of the sqlite table into a plant Simulation table
- use the ODBC Interface to transfer the data to the MS SQL database (you will need to setup your database as a ODBC data source first)
For the second step, you will need the Interface package.
If you use SQLite with a file, you can set up the sqlite database as ODBC data source (download a ODBC driver) and you can read it directly from your MS SQL database.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hello! can i use the SQLiteDemo to set as my default database on my ODBC data source? From here, I can connect to SQL server. is it possible?
then you need to set the SQLiteDemo also as the data source in the SQLite Interface in Plant Simulation.
Steffen Bangsow
web: www.bangsow.eu
Great! But how do I set the SQLiteDemo as the data source? Been thinking through for a moment and did not manage to do it. Appreciate it!
set in the path in the SQLite interface, Plant Simulation will create a file (if it not exists) if you access this file with the interface (SQL). Than you need to download and install a SQLite ODBC driver. After this you can set the database-file as a ODBC data source in window (look in the windows help, how to do this).
Steffen Bangsow
web: www.bangsow.eu
SQLite interface to plant simulation is new for me. I have to use it for my next model which shall provide a virtual model of one of our testrooms.
So have questions....
I have downloaded the example attached to this post. As I try to run it I get error in the OpenDB method, "SQLite.open" can not be processed, error: unable to database file.
As by your post, first I have downloaded the 64bit (my Window7 is 64bit) Precompiled Binaries for Windows from SQLite Download Center.
I probably need to ask out IT to install it on my PC.
Kind regards
Marco
what is your setting in the SQLite interface?
Default it is :memory:, that means, that you not need a file and the database is stored in the memory.
Steffen Bangsow
web: www.bangsow.eu
The setting is :memory, ... I see in attributes of .Models.OBSC.SQLite.
I have downloaded this example as linked into this post.
So I need the SQL related database/file related to this model.
Marco
picture show where you can find the sql-Example into Plant Simulation examples. This example works without sqllite instal.
SQL-Example.pngsqllite-demo
Nadin
