(HELP) one process with two different entities and go to different process afterwards
Hello!
I have one process (ParallelProc)  with two different entities. However, after being processed in this process, one entity goes to process 1 while the other goes to process 2.
And then after done with the processes, they will be stored in the same storage. Should I use Method/TableFile/other? Thanks for ur kind help Smiley Happy
12 REPLIES 12
Re: (HELP) one process with two different entities and go to different process afterwards
you can use the exit strategy "MU attribute"  to split the flow: select MU attribute and click apply, select as data type string and open the table, here you set name as attribute and type the name and the seccessor number into the table.
You dont need to program to do this.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
May I know which one should I click? Thanks!
tab exit - MU attribute
Steffen Bangsow
web: www.bangsow.eu
Is the attribute like MU.Container or the MU's name? And the previous process I use MU Container, once theey split, the entity is processed one by one, not as container or in one batch..  Sorry I am really new with technomatix and got no one to ask...
if you have different entities, then the names are also different; the name of the attibute is just: name
Steffen Bangsow
web: www.bangsow.eu
and what about the value means?
in the first column you write the name of the attribute (in your case: name),in the second column you write the name of the MU (e.g. blanket), in the third column the number of the successor: e.g. 1..., press enter and repeat it for the second MU-name  --> successor 2
Steffen Bangsow
web: www.bangsow.eu
Is it like this? I try to run the simulation, but it stack in the designated process....
yes, can you post your model again?
Steffen Bangsow
web: www.bangsow.eu
