Re: (HELP) one process with two different entities and go to different process afterwards
Thank you so much!
Blanket will go to CoolingDown process and for Linen goes to Checking process. and when folding and checking process is started, they will be processed one by one, not as whole batch or group...
the exit behavior is ok
two issues:
- don't use the cycle time: 20 minute cycle time means: each 20 minute can enter one MU the station, you need to set the processing time if the process should last 20 minutes
- your buffer capacity was 0, this blocks the flow
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Okay!!
Yes, I forgot to input them. Thank you very much (again), Steffen!!
