Helpe me with Transporter - train and wagons
Someone can help me with a simulation, it's attached here.
  I have two problems this case: the first is in transporter called "trem", my attribute "collisionControl" doesn't work correctly. I intend that "trem" coupling in others transporters called "prancha".
is
    i:integer;
    fzg:object;
do
    if self.~.backwards then
        fzg:=self.~;
        for i:=1 to self.~.num_pranchas loop
        -- is there a transporter
            if not isVoid(fzg.rearMU) then
                fzg.rearMU.hitchFront;
                fzg:=fzg.rearMU;
            else
                exitloop;
            end;
        next;
        wait(self.~.hookTime);
        self.~.backwards:=false;
        self.~.stopped:=false;
    end;
end;
The second error is in method of track
(SensorID : integer; Bug : boolean)
is
do
    -- let pass the tractor
    if not @.istrem then
        -- in a train only the tractor can stop
        @.gettrem.stopped:=true;
        if sensorID= 1 then
            waituntil load.occupied prio 1;
            load.cont.move(@);
        elseif sensorID =2 then
            waituntil unload.empty prio 1;
            @.cont.move(unload);
        end;
        @.gettrem.stopped:=false;
    end;
end;
Re: Helpe me with Transporter - train and wagons
Hi, there were a bunch of changes to get it running (s. attachment)
@sensorControl
is
do
 if not @.istractor then
  trem.stopped:=true;
  if sensorID= 1 then
   load.cont.move(@);
  end;
 end;
end;
@CollisonControl
is
	i:integer;
	fzg:object;
do
	-- if collide backwards --> hook trailer
	-- after hookTime move forewards
	fzg:=self.~;
	if fzg.backwards then
		for i:=1 to fzg.num_pranchas loop
				--fzg.rearMU.hitchRear;
				fzg:=fzg.rearMU;
			else
				exitloop;
			end;
		next;
	end;
end;
@init
is
	fzg :object;
do
	.MUs.prancha.create(track1, 1.5);
	.MUs.prancha.create(track1, 3.0);
	.MUs.prancha.create(track1, 4.5);
	trem:=.MUs.trem.create(track1,6.0);
	trem.backwards:=true;
	wait(1.0); -- just in case
end;
@pancha class
pancha.isTractor attribut set to false
Just in case, another way to do it.
I almost didn't touch the Onsensor ctrl.
Changes in Oncollision and Init.
cortega@interlatin.com.mx
+52 (81) 10801310
InterLatin S de RL de CV
