Hi forum, Need suggestion
Hi forum,
I am working on AGV systems which operated in 3 floors.
AGV1 -In First floor Agv will pick 34 entities of 3 types one by one into elevator to 3 rd floor.
Similarly 3 AGV dedicated in 3rd floor and 4 the floor.for material movement.
If it is in lift with AGV how to simulate it.
Please give me some suggestions.
Objective of simulation is bottle neck analysis of elevator.
Thanks in advance.
Re: Hi forum, Need suggestion
Hello Inventor,
Please help me understand your case,
- Is there only one elevator working in all four floors?
To model a lift, make use of a Tablefile/ list to update the Parts which needs to be elivated with From location (Floor number), To location (Floor number).
Then asign the task to the elevator to transport these parts to the respective location & delete the row from the Table.
or
Please make use of CrossSlidingCar object available in PlantSim.
View the PlantSim example model with category: Continuous material flow & Topic: CrossSlidingCar
Thanks & Best Regards,
Abhilash Sridhar
Mercedes Benz R&D India, Daimler AG
Thanks Abhilash for your quick reply We must use one elevator for material movement between floors. I really appreciate if you could explain with small example for better understanding. What ever you have shared your suggestion below: To model a lift, make use of a Tablefile/ list to update the Parts which needs to be elivated with From location (Floor number), To location (Floor number). Then asign the task to the elevator to transport these parts to the respective location & delete the row from the Table.
