How do I program a Reset-Method?
So I just started using Tecnomatix Plant Simulation 13 today and wanted to program a Reset-Method, so that the TimeSequence gets deleted before every simulation run.
I proceded to drag and drop a "Method" from the toolbar under the "information flow" tab into my frame. Then I double clicked it to open and typed in:
is
do
timeSequence.delete;
end;
but when I run it, I get the message "The source code contains syntax errors.". What am I doing wrong?
Also since I'm asking anyways is there a big difference between TPS 11 and TPS 13?
Re: How do I program a Reset-Method?
yes, the version 13 uses by default the new SimTalk syntax:
change your method; only:
timeSequence.delete
Then rename your method into "reset"
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I did what you said and it worked perfectly thanks a lot!
Regarding the versions. Do you, or someone else, maybe know where I can get TPS 11? When I go to the homepage to download the student version, the newest version TPS 13 automatically gets downloaded. Also I just checked out your book "Manufacturing Simulation with Plant Simulation and SimTalk". It seems that you used TPS 9 in that book, does reading that book help if I want to work with TPS 11?
Version 11 is no longer supported by Siemens. But you can switch off the new Syntax: if you open a method --> Tools - deactivate New Syntax
Steffen Bangsow
web: www.bangsow.eu
