How to access an "user defined attribute" placed inside a method through another method?
Builder
Builder
There´s a method that contains an user defined attribute type boolean called "my_attribute".
I want to print it through another method using the code:
print method.my_attribute;
plant simulation reports the following message:
A "void" cannot accept the method "my_attibute".
How can I cope with that?
Re: How to access an "user defined attribute" placed inside a method through another metho
This happens because when you write the method name, it executes the method. For this you require to set a reference to that method.
For this you assign the method to a variable of data type object..
See '&' or 'ref' in help..
Your case can look something like this...
var meth : object
meth:= &myMethod
print meth.myattribute
Builder
Builder
Good. Solved my problem. Thanks a lot!!!
