How to asseble two different product at a single assembly station?
I want to simulate a assembly staion which is processing four different parts.And the out put should be two different product.For example if there are four parts called A,B,C,D and i want a product with A+B called E as well as with C+D a product called F.But it should be assembled in the same assembly station with a single worker.Any help.Thanks in advance
Re: How to asseble two different product at a single assembly station?
is this what you mean ?
Yea that whyt i meant.Thanks a lot for your information and also for the quick reply.I am really thanksful to you :-)
